Re: Victor Gen2 Hemi heads, exhaust pushrod clearance, info
[Re: rickseeman]
#2666812
06/17/19 10:52 AM
06/17/19 10:52 AM
Posts: 17,865 S.E. Michigan
ZIPPY
S.E. Michigan
Hey Rick, this one is getting a solid street roller.
The rocker type, and the ratio is probably the biggest thing.
If I'm looking at it correctly, the shorter the "arm" on the pushrod side (higher the rocker ratio), the more likely the pushrod will hit the bottom of the tube. At least it seems this way comparing 1.52 to 1.55+
I've got good piston to valve clearance (now that I'm on my second cam), my intake valve relief has a little extra to accomodate the Edelbrock valve, so that all seems good to go.
Pretty small bump in the road really, but something tells me I'm not the first to encounter this.
Rich H.
Esse Quam Videri
Entire Thread
ZIPPY
06/14/19 05:36 PM
Cab_Burge
06/14/19 06:01 PM
rickseeman
06/15/19 02:07 PM
hemi-itis
06/16/19 03:17 PM
Cab_Burge
06/16/19 07:54 PM
an8sec70cuda
06/17/19 01:14 PM
ZIPPY
06/17/19 01:23 PM
rickseeman
06/17/19 02:40 PM
ZIPPY
06/17/19 02:52 PM
Cab_Burge
06/17/19 04:50 PM
Hot 340
09/14/21 03:31 PM
Dragula
09/14/21 03:32 PM
Hot 340
09/14/21 03:33 PM
Dragula
09/14/21 09:54 PM
W.I.N. Racing
09/15/21 02:10 AM
Cab_Burge
09/21/21 01:54 AM
ZIPPY
09/20/21 06:40 PM
crowbait
09/21/21 01:58 AM
ZIPPY
09/21/21 04:18 PM
crowbait
09/22/21 03:36 AM
ZIPPY
09/22/21 05:28 PM
crowbait
09/23/21 03:59 AM
BigDaddy440
09/23/21 04:44 AM
ZIPPY
09/23/21 12:09 PM
68 HEMI GTS
09/23/21 07:26 PM
ZIPPY
09/24/21 03:43 PM
Craig J
03/21/24 02:43 AM
ZIPPY
03/21/24 01:08 PM
6PKRTSE
03/21/24 02:35 PM
rickseeman
03/21/24 03:13 PM
6PKRTSE
03/21/24 03:57 PM
hemicar1971
03/24/24 09:13 PM
rickseeman
03/24/24 11:30 PM
rickseeman
03/25/24 01:26 PM
hemicar1971
03/25/24 05:27 PM
rickseeman
03/25/24 10:36 PM
ZIPPY
03/26/24 01:07 AM
hemicar1971
03/26/24 01:25 AM
ZIPPY
03/26/24 05:35 PM
Craig J
03/22/24 01:20 AM
Hot 340
03/25/24 01:43 PM
6PKRTSE
03/25/24 03:23 PM
Hot 340
03/25/24 04:41 PM
ZIPPY
06/17/19 01:17 PM
