Originally Posted by MI_Custumz
Originally Posted by Jwilli500
This, and check it correctly, meaning warmed up, in neutral, with the motor running...
Originally Posted by Tom_440
Have you checked the level of the transmission fluid? If its really low it could cause slipping.
The discussion about checking trans fluid came up at work the other day. I know it has to be checked while warm, but some said in neutral, some said in park, and some said it didn't matter. Does Mopar, GM, and Ford all get checked the same?
How to check the fluid level is usually stamped on the dip stick. Our old Mopars are a little unique in that the front pump is not circulating in park which is why we must check the level in neutral. I have no idea why they did it that way, it seems like a better idea to have the pump circulating all the time.
Master, again and still
