For guys using the TFI or GM coil, which has a solid male end, and still using the Mopar distributor.
For the coil wire, do you just use a regular spark plug wire (not a regular Mopar coil wire which has 2 male ends that go into female sockets).. with the "spark plug" end on the coil and the other end on the distributor?
