Pump hides behind the bracket......B.G. 240 HR. I wouldn't worry a ton about a vibration mount......you can use one , but it is sort of over kill I think. Might quiet the pump some , but that is about it.
Thank you tubtar! I was thinking of putting it up in front of the tank - is that not a good idea? Car will be on the street also, so is it a good idea to hang down in back?
