Thanks for the response A12. There is a separate chrome plastic trim that goes around the entire speedo cluster in my roadrunner. His car does not have this plastic trim piece like mine does. The speedometer lens appears to be the only thing that is different in the cluster like as you said, the 120 vs the 15/150 number lay out.
inherited a 69 roadrunner from my grand pop.
