Originally Posted By 360view
If you greatly dislike paying for gasoline consider buying a natural gas capable automobile or pickup. In many areas you can drill a modest depth well and get enough gas to fully charge a vehicle tank once a day. Geologic maps can show you where there are old capped gas wells that can easily produce enough methane to fill vehicles. You can also make methane with relatively simple bio-digesters.
I was taught that the world’s coal was the largest fossil fuel resource.
Today we know that natural gas worldwide and in sea floor methane hydrate deposits exceed coal by at least ten times.
That is not all good news.
If an modest asteroid hits an area of seafloor that has both methane hydrate and gypsum rock deposits... we are all doomed.
frown
No such thing as a 'modest well'....wells are complicated and costly. There are rules/regulations/permits that must be obtained. Existing capped wells belong to someone else and you can't just tap into them. Raw gas sometimes needs further refining to remove sour materials and moisture. It must be then compressed in order for a car's tank to be filled. Just not doable by a private party unless your property already has free gas....then the compression aspect is the limiting factor.
If any decent meteor hits earth anywhere....life is over.
1969 Buick Sportwagon 455 Stage 1 Ram Air SOLD
Nationwise Auto Parts Alumni 1982-1984
Now 1972 El Camino, original 402
