Originally Posted By fast68plymouth
The Super Victor is available with std ports for the RB block.
The Super Vic intakes are both the same casting imo,you can open the standard to max wedge . Plenty of meat there . That is what i did when going stockish to max wedge .
When fitting to non raised stock port i did have to cut a little top and bottom of intake face for clearance
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm
Power by Tex's Automotive
