What is the best intake for a 499 big block stroker
race only with a 1150 dominator
or can we use the adapator to use our 4150 manifold now
It depends on which size ports on which intake will work the best, I have change the bolt pattern size to fit Dominator carbs. on more than one intake, the last one was a Indy dual 4500 tunnel ram that I wanted to run a set of 4150 type throttle body with them in line for the linkage
On your deal make sure that the throttle blades will clear the intake manifold once you mount the carb by changing the bolt pattern
