Originally Posted By Cab_Burge
The tranny wiring harnesses are different for the 727 versus NP 833 so yes buy the one you need for the backup lights and if you want to use the clutch pedal safety starter circuit for your car buy the switch and wiring harness for the clutch pedal and install them at the same time up
I'm assuming that can still transfer over with a tremec t56?
