Like mentioned, big blocks probably have the worst issues because the only mounting points are the 3 bolts on each side of the block outlets. Just add a tension rod from the lower left corner of the block or timing cover, and come up at about a 45 degree angle to the front plate. That will greatly decrease shearing motion at the mounting flanges for the coolant passages.
