Not worth it in my opinion. If your setup could actually use the slight additional fade resistance, then you would benefit from a true big brake kit like the 13+" ones available, and that would be worth it. I'm saving for a Baer or Brembo type setup. Buy once and cry once. I've no direct experience with Wilwood but have heard a lot of non-complementary things about the performance of their front brake kits.
