No point in changing to that Wilwood kit from the factory 11.75 setup. If you want bigger better brakes then move up to a 13 x 1.25 kit with Brembo or Baer calipers. You'll notice a big difference between the factory 11.75 x 1 brakes and a 13 x 1.250 setup.
