The engine is 440 bored .040 over.
Flat top pistons at zero deck
'67 915 closed chamber heads with over sized valves, hardened seats and decked to 77cc chamber size
Stock forged crank ground 10/10
Stock rods, sized and balanced
Rotating assembly balanced.
Comp Cams XE285HL cam: Duration @ .050 = 241/247 Lift with 1.6 roller rockers = .582" LSA = 110
Edelbrock 440 Performer dual plane manifold
Holley 870 Street Avenger
MSD 6AL ignition with MSD Blaster Coil
Headman 78036 headers
2 1/2" exhaust
Hush Thrush Turbo mufflers
https://www.youtube.com/watch?feature=player_embedded&v=kYrzH5cyuUg
