I was thinking; do we know what cam is in the engine now? or are we assuming a stock magnum cam?
It has a COMP Cam XE268H high energy, which was OK. Just wondering if there's something better.
from my experience I don't like a comp cams 268 anything in a 440. for example; going from a comp cams 268/276 to a mopar 272/.455 I picked up 2-3mph in the quarter with a stock type engine. those 268's are 110lsa with 4 degrees of advance no matter what flavor you buy. they close the intake valve way too early. a cheapo summit 6401 is a better cam for what your doing. there are some lobes out there that may improve on the summit but will need to be custom ground.
