Who has a good cam recommendation for a 572 with indy 345 cnc 2.25 intake 181 exhaust heads. Indy tunnel ram with to alky 750 carbs. 14.1 compression with diamond flat tops. 4.500 bore 4.500 stroke. I have a set of 1.5 t&d or 1.6 T&D rockers i can use.
Race only setup in a dragster weighing 1955lbs with a 4.30 gear and 33.5 x16x16 tire.
Thanks in advance
Put shear plates under the carbs. Put a 1/2" spacer on the whole plenum, if it's the newer-style T/R you could make the spacer .75" thick. Use your 1.6 rockers on the intake side of current cam.
