Dozen-15 cars in PDRA usually. They put on a good show. And they're not all Camaros and a number of engine builders are involved. Looking at the 660 numbers they are pretty close to the 500" cars. Should be able to adjust some minimum weights a few pounds and be close. Glad to see it, should spark some interest in the class. I still like and appreciate the NA stuff. All about the motor.
If the results don't match the theory, change the theory.
