Could be the motor internal limit switch is bad. Check for power at the motor connector. There are 2 wires in the connector one is for up the other is for down. Check each wire separately with reference to chassis ground. Be sure to put the switch into the appropriate position.
Or you could unplug the motor and ground it. Then alternately apply power to each wire and see if the motor cycles
NS1AAR
