That mechanical pump setup is not going to give you a ton of volume or pressure. That said, I think your cam, converter and gear are holding you back more than anything. 3800lbs with that .520 lift cam and 4.10 gear on a 30 inch tall tire aren't going to make a ton of steam in my opinion.
