Im ready to run my new engine on a test stand to break in the cam and check for leaks. Im suppose to run .018 on the intake and .021 exhaust hot. Well the engine is cold and I need to set it to fire it up. What do you all recommend? Its an aluminum head 360 with a solid flat tappet cam. Thanks
