should be about 6 qrts. 7 with large filter/after start up & drain down
that's what mine takes with a oil/filter change with a large filter.
I had to replace the dip tube on mine, 90* inverted flare fitting in side of pan sump.
so I used a inverted flare bulk tube and cut to fit. welded the tab on tube then bolted to manifold bolt for support
the stick you have could be incorrect also. never know?
I would drain pan, change filter, add 5 qrts, run engine, wait 15 mins and check level.
if not on the stick I would trim tube a little at a time till I get a "add 1 qrt" reading on stick. then add 1 qrt, that should be spot on with a filter change and 6 qrt pan next time.
or get a longer stick and mark it or adjust tube length.
I mocked my pan on the bench and with my windage tray I run it with 5 qrts/filter to keep it 1 inch below tray. then adjusted my stick/tube to get "add 1 qrt" reading. use 6 qrts and filter it reads full.
what booster is on it? small BB booster or bigger flat pancake booster?
