Think there would be any issues with drilling my Cal vert monos? I need to slide the axle back to center the tire in the wheel well and i need the clearance for the bigger tire. Instead of buying another pair of front halfs, why couldn't i just drill another hole where it needs to be? Looks like the new hole would need to be drilled about 1/2" back from the other. I talked to cal vert about this a few years ago and they were totally against it, but i'm sure they don't want the liability. Thanks
