Aha of course! The shock bolt eye is much closer to the old endlink's mount axis than the E-body tab location on these arms (heck, OEM arms have the shock bracket almost longitudinally parallel with the swaybar mount hole)
I could use a longer + stronger shock mount bolt and use an endlink with an eye bushing/threaded rod construction to attach. There would be a mild amount of deflection on the rod end, but that gets me in a much better place than anything else I've come up with.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
