Originally Posted By Dave Hall
Just found that there is no alignment hole for the reverse lever on TWO '68 shifters. We are going to remove the detent ball and spring to see if that's the problem. If not, we will reinstall and try "swimming" the cover. Thanks again!
You can either buy/borrow the tool or drill a hole in the reverse shifter lever, forgot about those 68 Inland shifters...sorry
