Mock motor is in. The Mounts in these photos' are the V6 mounts from 88-93,
I've used Bouchillon's G3 mounts on 3 other swaps, but I'm not a fan of those mounts. http://bouchillonperformance.com/inc/sdetail/669/742
Drivers side should work out with just adding a plate, the Passenger side will need more work to get it in there right with out interfering with the oil filter boss.
