There is something crazy wrong here! It seems everyone has given some good insights. It could be a combination of probs, but I am going with the cam timing is off or the lifters are being crushed by too much preload {just a simple shimming of the rocker shafts would fix this}
with this statement, double check cam with degree wheel....also nice Challenger BTW...hope you can straighten this out, good luck!
