Originally Posted By sixpacksteve
900HP with a 727. Good Luck!
1100 hp in a 3700lb car for me. A&A built 727 with a Dynamic converter. Had $5200 into trans/ converter. Had two failures. one transbrake solenoid, and broke a tailshaft housing when a rear end broke. Very trouble free considering the power and weight. Guessing around 200 passes before selling the car.
"use it 'till it breaks, replace as needed"
