Originally Posted By kyhemi-dart
“billet input shaft & hub,alum drum,billet servo's,a&a 5 pinion planetary,a&a rear bearing support,a&a reverse pattern valuebody,a&a sprag,wide front band,all roller bearing transmission, spare case, carbon shield”
If the VB isn't LBA, I'd definitely upgrade to one.
The INTERNET, the MISinformation superhighway
