I used a circle track quick release hub welded to my c/m shaft. But almost any quick release will work. There are different bolt patterns/configurations on hubs, so make sure that whatever you get matches your steering wheel. The problem is going to be the way everything looks using a quick release on a stock column. Fabricating up something that looks right at the top of the column is going to be the biggest challenge.
On my stock Cuda column, I didn't use a quick release, but cut the lower portion of the column and welded tubing to it, then to a universal, more tubing and a splined universal to my Pinto rack.
