Yes, I would like to hear how it's easy as well. I spent years trying to hook a radial on a pretty nasty 6spd Fbody GM...going against other racer's advice in the process. When I finally did switch to ET Drag Bias Plys, my 60ft dropped 2 tenths immediately. More importantly it stayed consistent. When trying to launch a manual, track prep, pressure, and suspension are a magical combination. And, that combination usually only works on that track on that day. No doubt, they have the potential to go faster, but save yourself the headaches and run bias plys.
