So which DRIVEN Race Oil would be good for a race only engine shifting at 7600 small block? Going through the traps at 7770 rpm's
My suggestion is to go to the Driven Racing Oil web site and download their product brochures and tech articles. If you read the details of each of their race oils, you'll often see guidance such as using a Xw30 for bearing clearances up to .0027"; Xw40 for up to .0030", etc. They have enough info across their available downloads that it should give you a pretty good sense of what will work for you.
