I wonder if these same engines seeing wear have vacuum pumps sucking the oil away from piston pins and oil restriction issues to the rockers causing issues. Spray bar oiling??? I run the hell out of my crap and I'm not seeing it on my engines with Brad Penn 10-30. I'm not saying its not happening because those guys see a heck of a lot more engines than I see. Maybe i'm just lucky.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
