I checked the smaller 1.460" O.D. dual spring with damper (TFS-16893) and all the springs had consistent pressures but were to light for my cam without a bunch of shims. They were inline with TF's posted specs. I used Comp 930-16 springs to get 145lbs pressure on the seat.
The only Carbs I care about are under the hood!
