Originally Posted By cudadoug
Originally Posted By AndyF
I'm running both 240 and 270 heads right out of the box on my 470 engines. 700+ hp from each engine without any issues. I have about 90 pulls on the 240 heads, 30 pulls on the 270 heads.
With the as supplied springs??
Yes, I have the Trick Flow springs and retainers on my 240 heads. The 270 heads switched over to K950 springs when I put the super aggressive cam in it. The roller cam springs with the Ti retainers are high quality parts. Should be fine for most bracket type roller cams.
