The 440 source one is OK, the Hughes engines one is better and BRC's is the best in my opinion. The difference between the first two is the thickness of the girdle itself (everything else is basicly the same). BRC plate is 1/2" thick and is mounted differently. I've used all three, BRC is superior to the others.
