Originally Posted By dvw
Originally Posted By Mr.Yuck
The heads were done because of NHRA rules I believe. The ports have been moved and raised. This is a former members engine. It was designed to run 9's. The car is all steel, so I suspect it will be close to 3200 w/ driver and gas. It could probably run 9's on "pump gas". I'm just going to take it easy....
Looks good, but 3200 with driver? Not without a lot of gutting and light pieces. More like 3500-3700.
Doug
could be.. not sure. hood and deck lid are heavy. But a lot of the floor and trunk is sheet metal....no heater box, man steering and such.
