Originally Posted By Dartsport540
1 more
I run a Shogun remote water pump. Mounted on front frame rail. Pumps the water from radiator to engine, inlet side. It pumps the cooler water, from the radiator. BECOOL radiator, shroud and fan and recovery tank.
On a 90* to 100* day, my car will see a high temperature of 165* to 170*, when I get back to my pit after a run.
Dartsport, what are the dimensions of your radiator....was it custom made?
Thank you
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
