I can sell you some CP bullet series pistons and rings for less than that. Changing pistons is THE only way to go, because you really need to leave the heads unmilled. 9:1 is really where you should start....
How much? Need comp. height of 1.545 Chevy .927 pin dia. Valve reliefs And a weight of 522 grams
Diamond tech said his pistons because of new technology and machining processes would be lighter. I’d prefer not to rebalance.
6cc reliefs with flat top would be perfect.
"Old" member Registered: Sep 2001 Lost my credentials, I'm Back!! LOL 71 Ply Satellite Procharged 73 Dodge Dart Swinger 73 Ford F-100 390/Sniper efi/back to carb 01 Town and Country Limited 08 Dodge 2500 6.7 5" Deleted 02 Mercedes C230K 19 Camry
