This is a horrible pass but you can see how much movement as well as rotation is in the rear end housing myself I run about 7 degrees down. your car may only want 2.3.or4. https://youtu.be/gQEzZ2Xjzw0
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
