Hi Folks,
Finally I could test my new set of Viking DA Shocks that I installed in my car. These shocks already improve my 60ft from 1.58 to 1.54 but I'm still having tire bouncing on the start.
I'm using this setup on the Shocks:
Front: Compression = 12, Rebound 2.
Rear: Compression = 4, Rebound 12.
My car is an A Body, 3300lbs Small Block with 464WHP, Footbrake, 4500 Stall Converter, Hoosiers 28x10.5, 4.56 Gear, Leaf Springs with Assassin Traction Bars.
I'm sending two videos of the start... So if someone could see that and can support me to fix this issue will be great.
https://www.youtube.com/watch?v=kpsFBEn8U4A
https://www.youtube.com/watch?v=ErDPMz66wkw
Thanks,
Diego Reis
'77 Brazilian Dodge Charger R/T - Street Car
Footbrake, Pump Gas, SB Mopar 360" N/A
3300lbs, Leaf Spring + Assassin Bars
Best 1/8 mile ET
1.50 60' / 4.31 330' / 6.73@102.54mph
