Bretts weave welding skills are at a MAD level for sure...
Shiloh yes we have used spacer because of the tall deck height of the block. Only one cast intake is made for those heads and not meant for the tall deck. The spacers will be gone this coming year as the deck height is changing significantly. You saw the current intake earlier this year. It is getting more changes again. The carb adapter is not gone as well now as it is part of the intake, we still run the shear plate and its adjustable length cones.
