Originally Posted By rowin4
Installing bushing will not prevent a lifter from coming out of the bore if a push rod happened to break or come off the rocker for some reason. Most blocks are bushed because of alignment or wear problems. So if thats your reason , save your money.
no it won't but will help sustain oil pressure if you do loose one,that little .040 .060 hole in the bushing leak's a lot less oil than the big gaping hole that the factory intersection will, and yes my my block is bushed.
Light travels faster than the speed of sound,,,this is why some people seem bright untill you hear them speak.
