Hey Fast, do you think a standard port would work better at this weight to gain the velocity to move the car...........
This is definitely an "it depends" question.
The overall combo would have to be pretty mild for me to lean towards a std port window at 500"........ Or some other "special circumstance", like the owner had to have a 6bbl on a stock type manifold where the mw ports don't really work.
If you're building something in that 500"+ range, and you're trying to "make some power", and you have to buy heads anyway....... I think using std port heads just puts you at a disadvantage right from the start.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
