I like that Idea Medlock51 , not shure how much longer the block is at that point .
Looking at the pic above it seems the adaptor locates on the early cam via a recess and a dowl hole , then the outer diameter acts as the cam journal to fit in the larger cam bearing , and the length extends the sprocket forward the required amount .
