To answer your question, yes the booster along with the master cylinder should push the pedal back. Did you say you do have the bellcrank? The Ram Man has a video on youtube about trouble shooting boosters. One last thing after you get it to working and releasing, the pedal should be close to the floor, about the same as the gas pedal. That is the way power brakes are supposed to be, but not bottoming out on the floor.
