Re: Fuel Cell, foam or no foam?
[Re: Mr340]
#2386790
10/13/17 12:12 PM
10/13/17 12:12 PM
Posts: 7,506 Az
Crizila
Az
Part of the problem with foam is you have no way of knowing how much fuel you have in the tank. No fuel gauge ( unless you go outside the tank with a clear tube ) and you can't visibly see the fuel level. So you use a stick to check the fuel level. Stick goes right in to the foam. Not good! You break the foam up just a little bit, and your dead meat. Looking at the offerings on Summit's page they do show cells with foam and a sending unit. https://www.summitracing.com/parts/jzp-251-116-01/overview/ I stand rejected.
Fastest 300
Entire Thread
Mr340
10/11/17 09:28 PM
Thumperdart
10/11/17 09:38 PM
MR_P_BODY
10/11/17 10:12 PM
srunge55
10/11/17 10:28 PM
R3 Racing
10/11/17 10:34 PM
dvw
10/11/17 10:56 PM
Steve1118
10/11/17 11:19 PM
Mr340
10/12/17 12:20 AM
Dragula
10/13/17 03:40 AM
Crizila
10/12/17 01:15 AM
Crizila
10/13/17 04:56 AM
Stroker Scamp
10/13/17 06:08 AM
Mr340
10/13/17 01:41 PM
Crizila
10/13/17 04:12 PM
DavidDean
10/12/17 05:33 AM
an8sec70cuda
10/12/17 03:08 PM
10/12/17 04:58 PM
dogdays
10/12/17 11:50 PM
10/13/17 12:25 AM
Challenger 1
10/13/17 04:15 PM
Mr340
10/13/17 04:22 PM
Crizila
10/13/17 04:33 PM
