Kaases' MEL did fit the rules in terms of calling the deck plate his head gasket. However, What was that goop all over the "head gasket"? In years past you would have been asked to show what tube of goop you used--If it said GASKET MAKER anywhere on it then that would be considered the gasket and your deck plate would be ILLEGAL. Now if all the tube said was SEALANT then you were OK. J.Rob
