If peak go was the focus,I'm sure it would be , and did you see the torque curve
Actually, I couldn't find any info on it at all.
My point in the previous post was, the tq curve must be falling off pretty quick at some point in the run to only end up with 670hp when there were tq numbers in the 640 area within the tested range.
In other words, I'd think those 640tq numbers must have happened pretty early on in the pull.
If you have a link to where the results of the pulls are posted, I'd like seeing them.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
