Originally Posted By Supercuda
Do you know how stock Mopar endlinks attach?
throwing something out there. is there enough length on the sway bar arms to cut off the factory ends, then mill the remaining ends 90 degrees with corresponding holes to accommodate a "tie rod" style end ? i realize this small amount of shortening will affect the bar rate. the control arm mount could easily be fabbed to utilize this style of mount, and compensate for shortening of the bar.
beer
Yeah, you can do that. It gets well outside the realm of cheap though. I don't have a mill so I can buy one and learn how to use it or I can find a competent machine shop and pay them to do it.
I can shorten stock Viper end links with my current tool and skill set and wallet contents.
i keep forgetting i have an advantage over most, because of my 42+yr machinist skills, and my shop setup acquired over those many years that allows me to do things in retirement most have to source out. sorry. sometimes the ideas that are easy for me are beyond the realm of back yard "do it your self" technology.
beer
