Originally Posted By moparx
Originally Posted By Supercuda
Do you know how stock Mopar endlinks attach?
throwing something out there. is there enough length on the sway bar arms to cut off the factory ends, then mill the remaining ends 90 degrees with corresponding holes to accommodate a "tie rod" style end ? i realize this small amount of shortening will affect the bar rate. the control arm mount could easily be fabbed to utilize this style of mount, and compensate for shortening of the bar.
beer
Yeah, you can do that. It gets well outside the realm of cheap though. I don't have a mill so I can buy one and learn how to use it or I can find a competent machine shop and pay them to do it.
I can shorten stock Viper end links with my current tool and skill set and wallet contents.
They say there are no such thing as a stupid question.
They say there is always the exception that proves the rule.
Don't be the exception.
