I had a Carter street pump on my six pack set up and had trouble with it pushing past the needle valve. I put a fuel press gauge on it and with just the starter spinning the motor it read 9 psi. I went with a stock factory type six pack pump and so far so good. My motor puts about 380 HP to the rear wheels and while on the floor dyno the tech said it showed no signs of leaning out or starvation.
